I bought mine from Classic. See if you can get a used set with the bracket that they attach to (the steering column, dash, to firewall master cylinder support thingy). The manual pedals mount differently. I converted mine over but having a friend with a lathe to make the tube that the bushings slide into was helpful, Then just some drilling and welding. Good luck, Neill
When I did the swap I used a set of used pedals and they bolted right in to the existing bracket. There was no need for any other parts except for the new bushings to tighten things up.
If you use pontiac ones they bolt right in , the camaro pin type needs some work to make fit, the pin is diameter is larger and the pin is longer, yeah i have to make bushings that come on the camaro carrier and make the carrier hole larger... I have the pin type now but I really would like to find pontiac bolt on type..
