Posts: 310 |
I'm getting my Firebird rewired $2200 (oh the humanity)! Anyway, they took out the dash and now is the perfect time to replace that speaker (I think it's blown anyway). I'm running the original AM radio without AC and want something that fill fit in perfectly, so can anyone recommend a good quality speaker? If so, from where? Thanks!
1967 Pontiac Firebird 400 4 Speed Convertible 1973 Opel GT
Posts: 395 |
http://www.turnswitch.com/speakers.htmI believe this guy supplies most of the rest houses? He did my radio and rear speaker Gordy
1968 Firebird 400 4 Speed 68FB400
Posts: 310 |
Thanks Gordy. I just left him a vm.
Posts: 635 |
Berd, we talked to these people last week. they claim that one of thier speakers is the correct fit for our 69 dash speaker. They also put modern guts into radios for modern sound. www.retroradio.bizBill v
69 Firebird Convertible (wifes car since 1979) Goldenrod Yellow, 350, plain Jane Car was stored in garage since 1990
I need help, if anyone see's I'm going down the wrong road--Straighten me out!
Posts: 4,248 Likes: 14
Posts: 4,248 Likes: 14 |
Don't forget that if you're running the original radio you need a special speaker. I think it's 4 ohms. Modern speakers won't work with the original radios. Check Ames
Posts: 310 |
Posts: 73 |
@ the Berd and Bob S.
The link was attached earlier bit if you are using the original radio make sure you don't "over-cook it" with the new speaker technology.
".... Note: Many replacement speakers now sold by the discount stores, auto parts stores and mail order restoration parts houses are labeled as "4 to 8 ohm compatible" and are in fact 4 ohm speakers. These speakers can damage the older transistor radios. 4 ohm speakers will measure around 3.2 ohms with a DC ohmmeter. An 8 - 10 ohm speaker will measure around 7.4 ohms with a DC ohmmeter. The DC resistance is the critical number for the Delco radios as the output transistor is in series with the speaker. A properly operating Delco radio should have 1.5 volts DC across the speaker voice coil. A 4 ohm speaker will draw twice the current of an 8 ohm and cause the amplifier transistor (the half dollar size device mounted to the black finned heat sink on the back of a Delco radio) to run very hot. The speaker cone should be displaced in an upward (away from the magnet) direction about 1/8" when a Delco radio is turned on. If the cone moves down toward the magnet, the speaker leads need to be reversed. Ford and Chrysler radios of the period used the same type of germanium output transistors as the Delco radios and also require 8 ohm speakers. However, Ford and Chrysler radios ran with 0 to 1 volt DC offset on the speaker depending on the radio model and vintage. Many will not deflect the cone when turned on like the Delco radios.
Warning: Never run 4 ohm speakers on any vintage car automobile radio using transistor output circuits...."
Posts: 310 |
Posts298,897
143
