J Offline
I'm now done putting the nose section together and have a lot of pieces I no longer will need, headlight brackets and buckets, headlight metal surrounds, etc. I haven't bead blasted any but for an additional fee I could, I threw out anything that I wouldn't use so all is useable. Let me know if you need anything or a pic
Jerry Tallman
69 455/4sp Windward Blue, deluxe parchment bench seat, under major restoration
je_tallman@yahoo.com
A
A Offline
Do you have the latch support piece? And can i get pictures of the metal headlight surrounds?
I could stand to get a new batwing if you have one laying around.
J Offline
Had 2 latch supports but I can't find them, lots of stuff just up and disappeared, along with an extra batwing, I'm using an aftermarket one now
Jerry Tallman
A
A Offline
How about pictures of the metal headlight surrounds? Do you have the filler piece that goes between the lower valance and the core support?
J Offline
I'll get over to where they are as soon as I can, I bundled everything up and put in the trunk of my parts car, not sure what filler piece your referring to
Jerry Tallman
A
A Offline
Is this what you are talking about or do you mean the pan on ac and 400 cars
Yes the would be the latch with the support, and the other piece goes under the car and goes between the lower valance and the core support and goes from fender to fender.
J Offline
the a/c pan underneath is a hard one to come by, I only have one left and it's for my car, I sold a perfect one a few years back to year one, got $600 bucks for it. I guess they have a restoration dept. and it went on a car from Australia.
I've thought about trying to bend one up they don't look to complicated to do
Jerry Tallman
A
A Offline
So how much for the latch?
J Offline
As I said all extra latch assemblies seemed to have disappeared wish I knew where to. So none are available
Jerry Tallman
C
C Offline
Jerry, could you post up a pic of the a/c pan? Looked in the Year One catalog, does not look like they repop it.
Thanks,
Cal
J Offline
Will do
Jerry Tallman
J Offline
Thanks,
Cal
Here you go
Jerry Tallman
C
C Offline
Thanks Jerry,
Cal
N
N Offline
they do make them repo, I think NPD and/or Classic Industries sells them
J Offline
Repops are fiberglass I believe
Jerry Tallman
So this is only for an A/C car?
400's also. That reminds me, I have laying around I need to clean up and post!
Originally Posted By Flynbye
400's also. !
And 4 speeds, even 350-4's.
