#306405 06/05/16 01:28 PM
N
N Offline
Hi all,
which aftermarket manufactor has the highest quality for the Firebird first generation?
Does somebody had experience in using aftermarket body panels?
Greetings
I've used Dii goodmark AMD gold legion I think it depends I have found AMD seems to be the best quality on some of
parts the hoods and deck lids are good the 69 front fender not so much I had to do a lot of work to get that to fit right
And AMD has the thickest sheet metal I've found so far.
AMD has some of there own stamping dies but truthfully I think most parts are stamped in the same factory.
So its pretty much a crap shoot I buy mostly from summit so if a part is really bad I can return it
R81 Offline
Hi,
You should check Goodmark. They make complete quarter panels and also quarter skins and lower patch panels. Summit sells and delivers to Europe.
Riku
1968 RA I
