Posts: 6 |
Hi all,
which aftermarket manufactor has the highest quality for the Firebird first generation?
Does somebody had experience in using aftermarket body panels?
Greetings
Posts: 140 |
I've used Dii goodmark AMD gold legion I think it depends I have found AMD seems to be the best quality on some of parts the hoods and deck lids are good the 69 front fender not so much I had to do a lot of work to get that to fit right And AMD has the thickest sheet metal I've found so far. AMD has some of there own stamping dies but truthfully I think most parts are stamped in the same factory. So its pretty much a crap shoot I buy mostly from summit so if a part is really bad I can return it
Posts: 16 |
Hi, You should check Goodmark. They make complete quarter panels and also quarter skins and lower patch panels. Summit sells and delivers to Europe.
Riku 1968 RA I
1 members (Geoff),
2,339
111
