#307282 07/17/16 01:58 AM
Hi ,I've decide to replace my 194 light bulbs with DEL. I've remembered seing a post with a person trying different type of DEL and painting it aqua color but i'm not able to find it anymore.
I Have painted the exterior with weldtru primer to keep conductivity for the ground. Anyone remembering the post i'm taking about ? or have suggestion for a color instead of the baby blue ?
Also the plastic lens is a bit blemish any tips or product to bring back to a clear state
Thank you
I painted the inside of mine with fake chrome paint (really just bright silver.)
You can buy replacement lenses for the cluster. Otherwise a good plastic polish like somthing used on a motorcycle helmet faceshield or maybe headlight polishing kit.
-=>Lee<=-
I experimented and after repainting the interior of my cluster baby blue, I repainted it flat white. Now I have MUCH brighter instruments at night.
The headlight plastic polishing kits will work well on you clear bezel.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
Thank you for your answers. What did you guys used to replace the foam inside the cluster to seal each light. Also I found a kind of mirror paint wich seam to replicate the finish inside a headlight housing. I will try the chrome or the white and test everything out.
