If you have the aftermarket gauges for water temp, oil pressure and amperage, where do you route the wires through the firewall? Did you make a new hole or use an existing? Also where did you mount the gauge cluster? I wanted to put it under the ashtray but there isn't a lot of meat to mount. I was thinking about mounting to my console but I would rather not put holes in it.
