Posts: 34 |
If you have the aftermarket gauges for water temp, oil pressure and amperage, where do you route the wires through the firewall? Did you make a new hole or use an existing? Also where did you mount the gauge cluster? I wanted to put it under the ashtray but there isn't a lot of meat to mount. I was thinking about mounting to my console but I would rather not put holes in it.
Thanks for your help!
Posts: 338 |
This is what mine looks like. I ran the wires out the same hole as the speedo
1967 firebird
Posts: 338 |
This was right after I put it in.
1967 firebird
Posts: 34 |
Thanks! I think that is wear I'm going to mount it. It looks good there any will be a little higher to view.
I didn't try to run my wires yet but I didn't think they would be long enough to go to the speedo hole.
What is your red button for?
Posts: 338 |
What is your red button for? lol.. that's the smoke screen button...
1967 firebird
Posts: 34 |
The speedo hole worked great! Thanks again for your reply.
1 members (Dr. Drivability),
1,839
212
