Posts: 1,197 |
Looking for recommendations on which shocks I should buy to replace the factory shocks on my single-leaf 67 bird. I don't want to modify the body or factory look, just want it to ride better than a hay wagon. If it makes a difference, it is a convertible.
Thanks in advance!
Posts: 7,719 |
I will probably get flamed for this, but when Edelbrock discontinued the IAS line, I figured I better do the research and line up replacements in advance.
Totally based on, "Oh what the heck", I discovered that Koni makes shocks for FGF's.
Beyond that, there are a lot of people here that like they KYB shocks.
Posts: 1,197 |
Thanks for the feedback - will research KONI and KYB's a bit more.
Posts: 16 |
Hi, Konis no doubt. Quality, performance and comfort. Part # 80-1914 to front , 80-1915 rear. Check from: http://www.koni-na.com/en-US/NorthAmeric...;mk=36&mt=1They are on sale in Summit at the moment.
Riku 1968 RA I
Posts: 1,197 |
Thanks for the information. I will check these out!
Posts: 1,529 Likes: 41
Posts: 1,529 Likes: 41 |
KYb's been pretty good on the last 2 birds I did
Posts: 7,495 Likes: 1
Posts: 7,495 Likes: 1 |
Thing about the KYBs is gas shocks tend to be a bit harsher. Not as easily collapsed on impact with a bump so a bit more jarring than say a hydraulic shock would be. I've read that gas shocks add up to 40 pounds in spring rate to your existing leaf spring rate. Just a couple of things to consider. Hard to find a good hyd Shock these days. All modern cars use gas shocks I believe. I've got a practically new set for sale if anyone is looking..
Posts: 611 Likes: 3
Posts: 611 Likes: 3 |
KYB's on all four corners of my '68. I agree, can be a little harsh on rough roads.
Thanks, Dennis
1 members (Geoff),
2,339
111
