Looking for recommendations on which shocks I should buy to replace the factory shocks on my single-leaf 67 bird. I don't want to modify the body or factory look, just want it to ride better than a hay wagon. If it makes a difference, it is a convertible.
Thanks in advance!
1967 RA convertible
1968 H.O. coupe - sold
1976 Trans Am - sold
1985 Trans Am - sold
I will probably get flamed for this, but when Edelbrock discontinued the IAS line, I figured I better do the research and line up replacements in advance.
Totally based on, "Oh what the heck", I discovered that Koni makes shocks for FGF's.
Beyond that, there are a lot of people here that like they KYB shocks.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
Thanks for the feedback - will research KONI and KYB's a bit more.
1967 RA convertible
R81 Offline
Hi, Konis no doubt. Quality, performance and comfort. Part # 80-1914 to front , 80-1915 rear.
Check from:
http://www.koni-na.com/en-US/NorthAmeric...;mk=36&mt=1
They are on sale in Summit at the moment.
Riku
1968 RA I
Thanks for the information. I will check these out!
1967 RA convertible
KYb's been pretty good on the last 2 birds I did
Thing about the KYBs is gas shocks tend to be a bit harsher. Not as easily collapsed on impact with a bump so a bit more jarring than say a hydraulic shock would be. I've read that gas shocks add up to 40 pounds in spring rate to your existing leaf spring rate. Just a couple of things to consider. Hard to find a good hyd Shock these days. All modern cars use gas shocks I believe.
I've got a practically new set for sale if anyone is looking..
KYB's on all four corners of my '68. I agree, can be a little harsh on rough roads.
Thanks,
Dennis
