#309124 11/03/16 01:51 PM
J Offline
Have searched with not much luck. This car was a auto floor shifter, now converted to M21 with Muncie shifter. Can I use the existing factory hole with out making it any bigger? Without measuring it, I'm going to say it's about 3" x 4.5". What was the factory hole size? And can I convert my factory auto console to work with the Muncie?
Thanks in advance!
Your going to need a bigger hole. Someone here probably has a template for you.
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
S Offline
You can disassemble the console and purchase a new aftermarket 4sp "tunnel" that will bolt right in. No need to cut anything, as the hole for the auto plate is the same size that the 4 speed plate bolts into.
http://www.classicindustries.com/product/1968/firebird/parts/9793260.html
Cant wait for summer...
68HO4004spvert
Sleddog
Iowa
