10 bolt 8.2 Pontiac rear 1964-1972
power trax heavy duty posi locker unit
4 series open carrier
unit has been installed and bench checked for correct working operation.
brand new unit ready for your 3.36 3.55 3.73 3.90 4.10 4.33 and beyond ring gear ratio.
REMEMBER THE UNIT IS ALREADY ASSEMBLED IN THE OPEN CARRIER YOU DO NOT NEED TO DISASSEMBLE BOLT THE RING TO THE CARRIER ...INSTALL THE CARRIER IN PLACE OF YOUR OLD CARRIER... DOUBLE CHECK RING AND PINION BACKLASH. SLIDE THE AXLES INTO THE REAR AND BUTTON UP THE REAR WITH SEALANT AND FLUID AND GO HAVE FUN!
power trax part number is 92-0782-2801 (for Pontiac 10 bolt 8.2 rears
will fit gto 64-72 olds 8.2 64-67 Buick 8.2 64-67 also.
retails for 479.00 with out the open carrier -
asking 399.00 +shipping cost usually 15.00-20.00 for that except HI and AK. PR etc.
Thank you,
Akron, ohio[size:14pt][/size][font:Arial Black][/font]
Jim Mitschke
Richfield, Oh
J D Race
Good deal for someone wanting a posi without changing gear set.
