#322027 04/12/19 10:51 AM
M Offline
Generally Ames seems like a pretty good company they have HEI compatible Hood Tachs
Trying to get information on how they will connect to an HEI ignition.
Trying to find a pic
Thanks
they all will work with HEI, if you have one and don't have the wiring diagram, just call them, they get it for you
HEI is nothing more than a glorified hall effect, it would hook up the same as a pertronix kit, unilite, etc etc, same as points I believe, I have a pertronix II and it hooked up the same
M Offline
Thanks bartbird
If it's a GM HEI, there is a plug in connection on the distributor for the tach. Just get the connector from Ames. I hooked my original stock tach in my 69 goat to an HEI and it actually worked perfectly.
Bob S. #322036 04/13/19 10:09 AM
yep that's correct, not sure on original tachs but the new solid state tachs will work wih just about anything
