Posts: 1,202 Likes: 1
Posts: 1,202 Likes: 1 |
Can someone tell me the best way to clean up the original heater and A/C control assembly without tearing it apart? Mine is completely dirty (it is out of the car) and needs a good cleaning but with all the little parts attached to it I do not want to take a brush and start scrubbing it down. Can anyone suggest a good way of cleaning it without scrubbing on it?
Posts: 6,758 |
Spray it with a "Industrial Cleaner Degreaser concentrated" cleaning solution. It won't hurt the parts and removes dirt and grease faster than thinner or var-sol.
Spray it with a "Industrial Cleaner Degreaser concentrated" cleaning solution. It won't hurt the parts and removes dirt and grease faster than thinner or var-sol. Thanks Gus, I do have some purple power that I am thinking should do the job!!
Posts: 6,758 |
Be careful, read the bottle. Some solutions can damage painted surfaces or certain metals.
Be careful, read the bottle. Some solutions can damage painted surfaces or certain metals. Thanks for the heads up Gus! If I use this cleaner on it, should it be rinsed with water? As always, good info from you!
Posts298,894
85
