I was performing an under chassis inspection yesterday to check overall condition and determine what needs repair/replace and discovered the park brake cables are rubbing on the floor pan and starting to fray. I checked the service manual and I didn't see protective sheaths over the cables, just the exposed cable. So now I am concerned that maybe the floor pan has sunk and taken the rear portion of the X frame support with it. I have attached a few pictures so you can see what I am talking about. Is this the way it should look or do I need to put a plate under the floor and jack it back into position before replacing the rusty floor pans?
The door gaps are perfect and doors open/close nicely. I can't believe GM would have the brake cables rubbing on the floor pan, should there be cable sheaths on them?
