#327931 10/09/20 02:48 PM
M Offline
Sure this has been asked before but im looking for a company with the best hood tach for a 69 that I have set up with HEI
Ames has one or 239 says it will work with MSD
https://secure.amesperf.com/qilan/Detail_Web?part_num=FD354F&order_number_e=NTA3OTk2OQ%3D%3D%0A&web_access=Y
If anyone has purchased a tah and installed it in a NOS hood let me know how it went
I will have to have the hole drilled there is a pretty good you tube on this
MTJR69Bird #327935 10/09/20 03:50 PM
There is a template out there that has the main hole and mounting hole locations on it. Get yourself a hole saw set and a six pack and do it yourself, lol. I replaced my tach a couple of years ago, and if you want original style, I like mine that I got from "the parts place". They use a screwed on assembly not glued and real glass not plexiglass. Works well and looks stock with upgraded internals.
ramair68 #327938 10/10/20 12:04 PM
It can be a little intimidating drilling a 4" hole in a freshly painted hood but patience and having the right tools helps.It's really no big deal once you have the correct location.
Good luck.
Hank K.
Green Bay Wis.
Hank350 #327939 10/10/20 08:48 PM
You have to cut down through part of the under structure too with the hole saw. I used a new sharp one and it went through cleanly. I also cut my hood up for the ram air pan.
Bob S. #327940 10/10/20 09:27 PM
Same here. Measured about a dozen times and used a new bit. Unnerving but once done it looked great.
Larry
1967 Sprint Convertible
ramair68 #327959 10/15/20 10:23 PM
M Offline
I saw this
https://www.youtube.com/watch?v=VSaytPFquVg&t=85s
Does this look correct also I see a template for the 400 hood emblems for a 67 400 on FGF
have a 69 not sure if its the same
I bought a hood from ames pretty [censored] nice too except no holes drilled for the 400 emblems
I need that template looked around dont see one for a 69 is the 67 posted here the same ?
MTJR69Bird #327960 10/16/20 03:01 AM
W Offline
The same hood fits all 3 years for the First Gens, so I would assume emblem fit and location would be about the same.
wovenweb #327961 10/16/20 07:49 AM
Always check with Ames for dimension sketches. If it’s out there they prob have it. They will email it for free. I didn’t use a template. I had a drawing with all the hole locations dimensioned from the edge of the hood. I believe I got the drawing from Ames.
Bob S. #328011 10/22/20 12:04 AM
N
N Offline
Its an easy job, with a good drill bit and new metal snippers. Buy the Hood Tach that goes straight to your HEI distro and does not require any mods to the wiring. Mine has worked fine for 17 years now. Two bright bulbs light her up at night.
Bob S. #328012 10/22/20 12:22 AM
N
N Offline
Hoods for 67-69 were not exactly the same. The 69 hood in particular. I say this from the perspective of drilling and cutting a hood tach. Dimensions pretty close, but structure different.
