#327965 10/16/20 03:25 PM
Updated list on parts I'm selling. PM me for pictures or questions. Most all are original parts.
Driver's side fender extension 60.00
GM 25512339 A/T Sleeve 40-45 Teeth AC Delco 65.00
GM 60s 70s 80s new 41 TOOTH SPEEDOMETER GEAR 30.00
2 ea. Stant Locking Gas Cap G-92A with Keys Part in Box NOS 40.00
GM 38 TOOTH (2) SPEEDOMETER DRIVEN GEARS 1359272 35.00
350/400 A/T Modulator, GM 64-69 20.00
PPG Ditzler Dover White paint 375.00
8 original louvers, need re-chrome 50.00
Original Gas tank sending unit, 1 line, works good 60.00
Original Gas tank sending unit, 2 lines works good 80.00
Original armrests, green, paint to match- 1 with chrome, 1 w/o 50.00
67 original gas door 60.00
1 original door scuff plate 40.00
3 original Pontiac 14" hubcaps 90.00
1 DS original mirrors w/ edged #s glass 95.00
Brake Master cyl, Overhauled, disk brakes 150.00
GM Frigidaire A6 A/C Compressor, rebuilt 375.00
Rear brake drums 80.00
H/O decal fit, red 50.00
68 PONT Quadrajet 7028262 carb 650.00
Trunk light 50.00
Original speedmoter housing 35-39 gears 65.00
Front metal speaker covers, GM original, NEW! 80.00
Original print. circ. board, std. cluster 50.00
Original front brake lines, great shape! 60.00
Front pass. Side replacement Floor pan, US made 90.00
Drivers side below louvers patch panel, original! 80.00
Pass. side under fender blower motor area patch panel, orig. 120.00
Steering wheel wire cover, black, paint to match 40.00
4bbl throttle cable, new, OEM style 55.00
GM 3:55 Differential Ring and Pinion 8.2 250.00
Original A/C dryer 50.00
NOS AC Delco ignition coil 60.00
NOS AC Delco distributor cap 50.00
NOS Delco distributor rotor 15.00
68 clock w/ red dials/shite second hand 225.00
2 Hub caps 80.00
67/68 ashtray assembly original 75.00
Windshield spray nozzles Squirters original 40.00
K
K Offline
PM sent
68 400 convertible - recent purchase
Used to own:
69 400 convertible - Winward Blue
69 350 convertible - Verdoro Green
69 350 coupe - Matador Red
Hi
More info on the nos coil please and rotor and cap
part number picture etc
thanks
when u have time
Here you go....
cap s-l1600 (1).jpg cap2s-l1600 (3).jpg cap3s-l1600 (3).jpg IMG_20200422_163249477.jpg IMG_20201013_133434977.jpg IMG_20201013_133458799_BURST000_COVER.jpg
1 members (Jimc2002), 114 guests, and 19 robots.
