Posts: 22 |
Hey guys, This weekend, I will start removing the hood, fenders, and front radiator support to get access to the subframe. I plan to order a rebuild kit for the front suspension (ball joints, tie rods, etc.) along with the six-frame to body bushings. While cleaning and painting, what else should I GET DONE while it's apart, or what should I replace while putting it back together? Suggestions and tips are what I am seeking today, folks. Thanks, guys, Brian
Posts: 6,158 Likes: 51
Posts: 6,158 Likes: 51 |
Probably a good time to replace the old splash shields, other engine compartment rubber seals and, if you have a 400 or AC equipped Bird, do all the radiator to core support masticated rubber fillers. See Ames Firebird catalog page 240.
Jim '68 400HO Conv.
Posts: 280 |
Don't worry about the "should I" my experience is plenty of "need to" will present themselves! LOL Honestly its a long list of possibles. It's like when you pull an engine.... well no that its out....
Posts: 147 |
How about some pictures of the front torn down?
Posts: 611 Likes: 3
Posts: 611 Likes: 3 |
Carefully check subframe for cracks or broken welds.
Thanks, Dennis
Posts: 3,049 Likes: 10
Posts: 3,049 Likes: 10 |
Brake lines and disc brake conversion if it's not equipped already. A lot easier with the sheet metal out of the way.
Posts: 22 |
I also have a 1967 Porsche that has a factory disc on all four, and my thinking is to convert the drums in the Firebird to a disc as well. At one time, I read something that listed the parts one could pull from another GM car to swap out, but I can't seem to find that list now  AUGHHHH. I am not sure how I feel about a NEW kit on this car; I sort of want to keep as a period correct as I can. Brian
410
58
