Posts: 45 |
I did a little searching but was unable to find what I was looking for. Does anyone know what the proper torque is when attaching the rear end to the leaf springs. The 12 bolt I am using has 4 bolts per side. I suspect that is standard. Any help would be appreciated.
Greg
Posts: 612 Likes: 3
Posts: 612 Likes: 3 |
If using 1/2-20 u bolts then 90 ft lbs
Thanks, Dennis
Posts: 45 |
Thanks Dennis there are no ubolts on this rear end. The bolts are part of the rear end.
Posts: 426 |
I have dealt with quite a few 12 bolts in my time and have never seen the bolts part of the rear end. Are you sure someone didn't just drop bolts in? if so, replace with u bolts. Also don't forget to re check the torque after 2 or 3 trips and again a 3rd time about 10 trips later. They will loosen when they settle in.
Posts298,899
158
