Posts: 1,536 Likes: 4
Site Admn
Site Admn
Posts: 1,536 Likes: 4 |
To add photos or other documents to your post, use our Attachment Manager. This can found using the Use Full Editor button below the text box you type messages. See photos below:
Click on Use Full Editor
Click on Attachment Manager and then follow the directions
Posts: 7,495 Likes: 1
Posts: 7,495 Likes: 1 |
G, iwas going to add another pic to my photo gallery but after I click on full editor button the attachment manager button doesn't appear in the next screen and it says HTML disabled. I went at it a couple different ways but couldn't figure it out.
Posts: 794 |
I know this is old but did you ever figure this out? I am having the same issue
Posts: 6,161 Likes: 51
Posts: 6,161 Likes: 51 |
I'll try a test picture post:
Jim '68 400HO Conv.
Posts: 794 |
[[img] https://firstgenfirebird.org/forums/ubbthreads.php/ubb/download/Number/20080/filename/Firebird Dash housing.JPG[/img] This is what i get when i try to post. I have tried renaming file etc. When i pull it over is shows the image then when i click to add it, it comes up as this
Posts: 794 |
Okay, never mind it doenst show the image till i hit post!! Thanks for the help!!
Posts: 489 Likes: 11
Posts: 489 Likes: 11 |
I can't seem to post images correctly. Some do, some don't, yet I run them through the attachment manager the same way. No rhyme or reason. Is it the size? Or is there a limit? On another site I use I can only add three at a time. I have to continue the pics as another reply. I am sure there is a simple answer but I can't see it right now. This is how a bad pic shows up; [img] https://firstgenfirebird.org/forums/ubbthreads.php/ubb/download/Number/20199/filename/IMG_0570.JPG[/img] When I see it in the reply the last [/img] is underlined in red as if a misspelling. But that is what it should be, right?
I figured it out, and as I said, every site is different. On this site when I open the Attachment Manager I cannot just drag a pic from my Olympus Master program. I store all my pictures there and on most sites I can just drag them over. . What I have to do is click on 'Select a file to attach', and that opens a window in my Windows 10 'this PC- pictures', go into my Olympus files, click on the pics, and take the pics from there. Then they get stored in the Manager and when I hit 'POST', there they are. Whew. Took a while but I get it now.
560
