#333136 04/20/23 03:09 AM
I have most of the accessories off a running
68 400 Fire bird YT engine
Air cleaner PP code real nice base ….poor chrome top elbow and breather tube included
275
Service q jet 150
Fast idle solenoid n bracket works great 250
Th400 lockdown works w bracket no boot 150
Throttle bracket w correct coil n bracket 200 original lug wire bracket too
Intake L-67. 125
Thermo housing w orig bolts NO pitting 50
Alt brackets 35
Power steering pumps ac and non ac
Exhaust manifolds nice dated pair 175
1100704 alt mint case tight bearing 100
Sweet timing cover 1 year no pitting 225
Correct late 67 for68 flex fan and original spacer and bolts 150
Th400 PX original nice fluid 88k. 375
Non ac crank pulley 9790846 68-69. 45
69 water pump pulley 9796060 4” pump 35
Plus odds n ends
Oil filter adapter correct bolts and exhaust manifold riser bracket 65
68 wood wheel tired but complete 300
67-68 vinyl top stainless around bottom
1 soft ding nice originals 125
Pass side windshield stainless nice 35
69 1111270 distributor 325
Offers considered
Thanks
Scott
2o6-4six5-91six5. 7am-9pm pacific
Tacoma Wa
86FE05C3-6F9F-4302-857F-F9199FA3BDB4.jpeg 67815457-65A4-4AF6-B026-F32BE52C8AE5.jpeg 7107EF70-89E7-4661-8564-5AC4743FB7C1.jpeg B4360355-4A39-4566-94C5-F3836087D64A.jpeg 1D74F321-EBF6-42B9-9884-659326B229CF.jpeg BF6D4ACE-B626-4007-B295-C41203EF2A13.jpeg 870A8C79-AE16-4F00-B086-DF10169F358B.jpeg 8C23C280-80F9-4388-ACC0-0009512D5FF6.jpeg 5E78163D-40D3-4D2A-B4AC-264FFC05C952.jpeg DCF5F164-CA28-4C65-8004-515C994501DC.jpeg
W Offline
This is probably the best "parts for sale" post I have seen. Your organization and info is top flight. Not to mention the condition of the parts... this engine even had that weird castlated nut still present on the thermo housing/alternator bracket stud. I don't need anything here but had to heap some praise for a moment smile Nice work Scott!
I’ll take the carb.
PM on the way.
Brian
Thanks Widetrack. !!
Pm retuned
Scott
Actually the engine is available again. Deal fell thru
YT w 16 heads all date coded except arb n distributor
