Posts: 309 |
I have most of the accessories off a running 68 400 Fire bird YT engine
Air cleaner PP code real nice base ….poor chrome top elbow and breather tube included 275 Service q jet 150 Fast idle solenoid n bracket works great 250 Th400 lockdown works w bracket no boot 150 Throttle bracket w correct coil n bracket 200 original lug wire bracket too Intake L-67. 125 Thermo housing w orig bolts NO pitting 50 Alt brackets 35 Power steering pumps ac and non ac Exhaust manifolds nice dated pair 175 1100704 alt mint case tight bearing 100 Sweet timing cover 1 year no pitting 225 Correct late 67 for68 flex fan and original spacer and bolts 150 Th400 PX original nice fluid 88k. 375 Non ac crank pulley 9790846 68-69. 45 69 water pump pulley 9796060 4” pump 35 Plus odds n ends Oil filter adapter correct bolts and exhaust manifold riser bracket 65
68 wood wheel tired but complete 300 67-68 vinyl top stainless around bottom 1 soft ding nice originals 125 Pass side windshield stainless nice 35 69 1111270 distributor 325
Offers considered Thanks Scott 2o6-4six5-91six5. 7am-9pm pacific Tacoma Wa
Posts: 118 |
This is probably the best "parts for sale" post I have seen. Your organization and info is top flight. Not to mention the condition of the parts... this engine even had that weird castlated nut still present on the thermo housing/alternator bracket stud. I don't need anything here but had to heap some praise for a moment  Nice work Scott!
Posts: 20 |
I’ll take the carb.
PM on the way.
Brian
Posts: 309 |
Thanks Widetrack. !! Pm retuned
Scott
Actually the engine is available again. Deal fell thru
YT w 16 heads all date coded except arb n distributor
1,607
119
