Would be oh so grateful to see an up-close image of a working Parking Brake handle; how it connects to the gear/release mechanism in particular.
The rod and handle on my bird is completely gone and I'm looking for options. Could replace the whole mechanism, but it's $90.
Thanks!
1969 Firebird, 350-2v/350, Verdoro Green (?), Green vinyl, numbers matching, relatively unmolested. Needs a bit of everything.
O
O Offline
Look at Firebird Central parts. Parking brake control The middle pic is what you want.
Thanks brother! I'll see if I can fabricate something. A screw-driver isn't the sexiest solution, but it's what I've been using.
And thanks for the response on the A/C stuff. When I figure out where this car is heading, I may put all this A/C stuff back in.
1 member likes this: Oldslowandugly
P
P Offline
Had the
same issue, I ordered a whole new unit from Ames for $69.00
O
O Offline
Always check Franks Pontiac Parts.Franks Stuff comes and goes quickly but since you are in Cali you may get lucky. And like I said, AC was rare in our cars. If I had it I would restore it. You already have the hard to find parts like the ductwork and controls. A rebuilt compressor, new evaporator, new condenser, all are easy to get.
