Posts: 9 |
Hi,
Trying to find inserts for my 68 which has these arms and not having much luck. Anyone have a part number that matches this? Images attached.
  1968 Firebird 350|#17 Heads|Cam identical to 350 H.O. specs|Holley 650DP (mech, secondaries)|Edelbrock Performer Intake|Manual 4 Speed with 3:73 rear
Posts: 853 Likes: 3
Posts: 853 Likes: 3 |
Wade
Posts: 853 Likes: 3
Wade
Posts: 1,363 |
I tried a set, look good but incredibly hard to install. The loops on top of the blade are too high and run into the frame.
Larry 1967 Sprint Convertible
Posts: 6,158 Likes: 51
Posts: 6,158 Likes: 51 |
I tried a set, look good but incredibly hard to install. The loops on top of the blade are too high and run into the frame. Larry, Do you have the original or accurate replacement wiper arms for your convert? They are different than the coupe and there is a right and left side arm for the convert. The left being 1/4 inch shorter than the right.
Jim '68 400HO Conv.
Posts: 1,363 |
Not sure, didn't know they were different I actually bought two sets of these refills, one for the FB and one for the GTO. PITA to install.
Posts: 1,363 |
Just checked, one of them is about a 1/4" shorter. Never knew that. Always thought they were the same.
1 members (Geoff),
2,339
111
