Started my "68 up today after sitting for 3 weeks. Ran great last time started. It starts, but is idling rough and intermittently "banging" and back firing. It eventually will stop running, but can be started back up. When I started it 3 weeks ago, I checked the timing. 9 degrees at idle and 35 degrees at WOT. I did not change anything. Spark plug wires are not loose and have not been burned through to cause it to short. Distributor is tightened down, ie won't turn.
