Posts: 14 |
Started my "68 up today after sitting for 3 weeks. Ran great last time started. It starts, but is idling rough and intermittently "banging" and back firing. It eventually will stop running, but can be started back up. When I started it 3 weeks ago, I checked the timing. 9 degrees at idle and 35 degrees at WOT. I did not change anything. Spark plug wires are not loose and have not been burned through to cause it to short. Distributor is tightened down, ie won't turn.
Any ideas?
Thanks
Posts: 13 |
Posts: 1,529 Likes: 41
Posts: 1,529 Likes: 41 |
Is the carb flooding over or is the choke stuck closed?
Posts: 6,158 Likes: 51
Posts: 6,158 Likes: 51 |
Has the original nylon-coated timing gear and chain ever been replaced? Could the chain have skipped a gear tooth or two?
Jim '68 400HO Conv.
Posts: 14 |
ETZKORN,
Thanks for the suggestion, that something I never would have considered. I think the fuel is ok, but I'll keep that in mind as i troubleshoot.
Thanks
Posts: 14 |
Bigchief,
I let it sit for a day, and will try again today. The choke looks ok.
Thanks for the suggestion.
Posts: 14 |
JimC2002
I am the 5th owner and to be honest have never looked at the timing chain or know if it's ever been replaced.
I'll take a look to see if I can figure that out.
2 members (Geoff, Jimc2002),
469
119
