Posts: 64 |
I have been suffering with a driveline vibration since restoring my 67 coupe that comes in at about 50 mph and resonates under the drivers seat. I noticed some play in the prop shaft where the yoke goes in the tail shaft so I replaced the tail shaft bushing and had the prop shaft balanced at the same time. Took it for a test drive and no vibration, so I thought great problem fixed. Now after about 100 miles the vibration has gradually come back to how it was before. Any advise on what to try next would be much appreciated. Thanks
Posts: 1,548 Likes: 41
Posts: 1,548 Likes: 41 |
Did anybody check the U Joints ?
Posts: 64 |
hi Yes UJs are new and were on the prop shaft when balanced, from what i have read I probably need to check the pinion angel next as that may be causing the problem.
Yes see what the pinion Angel has to say
Topics35,551
Posts298,919
Members8,869
58
