Posts: 17 |
Looking for some opinions, comments, suggestions, pros & cons on my next dilemma.
My car is an original 400 A/C car which had a fair amount of options, not all of which are still on the car. I am not going for a true & correct resto, but would like to keep it reasonably original. Under the hood, the only remains of the a/c system is the evaporator box and some wiring. Getting a working A/C is not a short term goal, but some day I would like to put a system in.
Currently, I have to replace my heater core. Something I am not looking forward to, but has to be done. Since it will require pulling the fender and part of the dash anyway, I want to plan ahead for what type of A/C to put back in: The original set up or go with more modern Vintage Air type system.
I like the idea of the modern units not having the large combersome a/c box which frees up a lot of space under the hood. If I go this route, I will go ahead and take out the evaporator case now. If I go back to original, then I will leave it alone.
Questions: -The Vintage Air set up's I've seen are designed for non A/c cars. Are there packages for cars that did have A/C? What are the differences?
-What are the differences in cooling performance of the two systems as well as costs?
-Would I significantly hurt the value of the car by not putting it back to original?
-If I go aftermarket, what heater core would be recommended? If original, what's the best source for the heater core?
Thanks for any input. Wayne
Posts: 11,905 |
1. Value only matters if you sell. Chances are you won't recover the added cost of an aftermarket A/C system if you do. 2. Check into the controls first; since Vintage Air was made for non-A/C cars, the controller mounts differently and your stock A/C heater control will be an orphan, along with ductwork, cables, dash vents, etc. 3. For what you save on not buying an original A/C system you could probably buy a Vintage Air and save the space, or conversely for what you'd spend on a Vintage Air you could rebuild the factory A/C. 4. Factory A/C is excellent, if charged with R-12 Freon as designed. Use of lower efficiency refrigerants will decrease the performance of the cooling system. I often run the A/C with the convertible top down during 90+ degree August cruises, and it does keep me cool. 5. With the factory A/C you will cuss every time you need to work on the right bank, but remember you have a rare 'bird with factory A/C, and that's the price you pay for having a highly optioned car.
These are all my opinions, and I'm sticking to them. :p
Posts: 1,016 |
Rick's First Generation sells a kit to convert an A/C firewall to a non A/C firewall. You would then be able to install the Vintage air system.
If you go this route, you will no longer need the inside unit (which is different on A/C cars) since the Vintage Air unit will replace it.
Tom
1969 400 Convertible
Posts: 14,265 |
Many people that live in the southern states will only buy cars with air conditioning. Air conditioning raises appraisals about 15%. It pays for itself. Aftermarket AC mounts under the dash on the passenger side. If you have a long legged  passenger or one that doesn't appreciate the cold vent in front of them, they may be unhappy  . I really like my original air conditioning and it wasn't that hard making it work. Jim
Posts: 312 |
trmjr1 could you tell me the part # for the kit from Rick's 1st Gen to convert from a AC to non-AC firewall? I went to the online site but I could not find that item. Thanks
Posts: 20,054 |
since you say you are not doiung your car 100% original, I`d go with Vintage air, cost about $950, reasons : 1) more space around your last two spark plugs 2) modern unit, easy to get parts for, using R134
Posts: 11,905 |
Since you're already not going original, I wonder if it would be feasible to use a later model Pontiac A/C which uses a smaller suitcase? Then perhaps you could retain the original ductwork and controls.
Posts: 20,054 |
With Vintage ,you also retain the controls....
Posts: 1,016 |
David,
I sure thought it was Rick's - I went through the catalog and found an "Evaporator Box Eliminator" - P/N AC-95 and they list a "Complete Firewall (w/o A/C)" - P/N PP-165.
I will have to look through my other catalogs - I know I saw the kit listed somewhere...
Tom
Posts: 17 |
Thanks for the replies so far. Still welcome more.
Yellowbird, you're right on the mark with #3 it's a flip of the coin cost wise. #5 makes me want to keep it original.
Any suggestions on vender for a best fit orignal heater core?
Posts: 20,054 |
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> suggestions on vender for a best fit orignal heater core? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">might try Terry Ritter (954) 721-1459 or Bill Edmonds earlybrds@aol.com for good used?
Posts: 14,265 |
Ames has an exact fit. Jim
Posts298,897
122
