Okay here is my problem. I bought a delco r59 repro 3 or 4 yrs ago. I use it 6 mnths then put it on a trickle charger in the winter,and its always been dependable. Until now. I always check the water level but when I got it out this spring one of the cells was very low on water. The battery will take a charge and be dead by morning. As these are very expensive I and original I would like to save it.Is it feasible to empty the battery like it was when I got it,refill it and start over? Also if it is I cant remember how much acid I put in before I topped it off with water. Any help would be appreciated!!
Do a Google search for a battery charger that dissolves the sulfates that collect on the plates. They run about $90. They operate by charging with a baised AC current that oscillates at the resonant frequency of the sulfate crystals, dissolving them back into solution.
Morning Dan, As it turns out I was just reading about a product that if true, could be your answer. Check at www.batteryequaliser.com I have some VX-6 battery rejuvenator at home. It is endorsed by Lee Petty. It may be a little old by now huh. I've had some tell me to empty it and refill it with electrolyte. When batteries were shipped dry and filled at purchase, you filled them all the way to the top. Happy Cranking,
Thank you both. You are wise beyond your years! I think because the electrolyte is inexpensive I will empty it,refill it,charge it, and have it tested. If thats a no-go i will try one of the options you suggest Thanks again!
