What are peoples thoughts on the best way to store fresh heads so they are ready to go when the rest of the engine is ready? Its going to be a while and I want to make sure they dont rust or anything.
Not an expert on this but I would use something like G-96 (used for rifles) or something along that line (a light oil coating) then wrap them in a cloth and store them in a dry area, ie not the garage if you are on the coast as I am where it is humid.
Or put them in Plastic bags and liberally coat the inside of bag and heads w/wd-40. Seal up tight. Then don't forget to keep rechecking them every so often and respray if ness.
Swedish military maintains troops use dry- air almost everywhere, Army, Navy and Airforce. It just make time stand still. If you can get air under 50% air humid ( think it was 50 or perhaps 30%) metal won’t rust or Aluminum won’t oxidize. Here in Sweden it becomes more and more popular with air dryer for bathrooms and garages. Anyone who has tried this? A big well known company dealing with dry-air is Munthers
Tommy
Tommy Firebird 68 conv 350 HO Cougar 70 conv 351 Cl 4V It’s only dead fishes swimming with the stream!
I would not use WD-40, it contains water. Any type for light oil should work. Sorry Doug, not trying to put you down or anything, but I'm not a big fan of WD-40 and not to many people know it contains water. I use LPS
1967 Firebird: 326ci, Holley 670cfm street avenger, RPM intake, Headmann headers, HEI
Mike, great to see you are still here now and then! Sounds like the bird is getting closer and closer!
I would check with a machine shop in the area. Should still be a few good ones in San Carlos/Belmont or Redwood City that can give you the best advice. But I do agree, cosmoline is about as good as it gets. Most machined parts are shipped with this stuff on it... But a good light oil will do the trick. Just re apply now and then.
Just bought a set of heads for my bird recently too, but they are not new... and when I build them up, tye will get swapped out right away.
I stored my #16 heads for about two years after I had them done. I sprayed them with Sprayon #711 spray (kind of like WD-40, but made for this purpose), and I tied them up in garbage bags. I kept them in my garage and they were ready to go when I finally got ready to use them this past winter.
