M Offline
Hi,
What are peoples thoughts on the best way to store fresh heads so they are ready to go when the rest of the engine is ready? Its going to be a while and I want to make sure they dont rust or anything.
Thanks for the guidance,
Mike
Not an expert on this but I would use something like G-96 (used for rifles) or something along that line (a light oil coating) then wrap them in a cloth and store them in a dry area, ie not the garage if you are on the coast as I am where it is humid.
David
68 Droptop 400 4 spd.
3 Offline
Or put them in Plastic bags and liberally coat the inside of bag and heads w/wd-40.
Seal up tight.
Then don't forget to keep rechecking them every so often and respray if ness.
The pros use Cosmoline. It's a spray on waxy substance. Available at your industrial supply store. Lasts forever.
N
N Offline
My garage has been certified as a great place to store these. Send to:
Nash
882 Countrywood Drive
Adams, TN 37010
Bought a set of heads from a guy that had them in a barrel of waste oil. Stinky good!
Swedish military maintains troops use dry- air almost everywhere, Army, Navy and Airforce. It just make time stand still. If you can get air under 50% air humid ( think it was 50 or perhaps 30%) metal won’t rust or Aluminum won’t oxidize. Here in Sweden it becomes more and more popular with air dryer for bathrooms and garages. Anyone who has tried this? A big well known company dealing with dry-air is Munthers
Tommy
Tommy
Firebird 68 conv 350 HO
Cougar 70 conv 351 Cl 4V
It’s only dead fishes swimming with the stream!
2 Offline
Seal up tight.
I would not use WD-40, it contains water. Any type for light oil should work.
Sorry Doug, not trying to put you down or anything, but I'm not a big fan of WD-40 and not to many people know it contains water. I use LPS
1967 Firebird: 326ci, Holley 670cfm street avenger, RPM intake, Headmann headers, HEI
Mike, great to see you are still here now and then! Sounds like the bird is getting closer and closer!
I would check with a machine shop in the area. Should still be a few good ones in San Carlos/Belmont or Redwood City that can give you the best advice. But I do agree, cosmoline is about as good as it gets. Most machined parts are shipped with this stuff on it... But a good light oil will do the trick. Just re apply now and then.
Just bought a set of heads for my bird recently too, but they are not new... and when I build them up, tye will get swapped out right away. smile
Good to see you chime in!
Brett!
[Linked Image]
I stored my #16 heads for about two years after I had them done. I sprayed them with Sprayon #711 spray (kind of like WD-40, but made for this purpose), and I tied them up in garbage bags. I kept them in my garage and they were ready to go when I finally got ready to use them this past winter.
John
0 members (), 560 guests, and 21 robots.
JFF 1
