I need some help with my rally gauge cluster, the factory indash type. I am getting absolutely no power to it, lights do not even work. The cluster itself is a used original, the dash harness is new, all fuses are new and I even just tried a new printed circuit. Still no power. I have power to the rest of the dash, wipers, radio, heater, horn, except not to the cluster. Any ideas??????????
No, but I had no power to my rally guages only last week. Gave up for now and put a temp pwr wire in from the accessory tab (switched) on the fusebox to one of the guage taps. That backfed the rest. Not saying finding the problem is not a good idea, but it all works now.
Well I have power at the wiring harness coming into the cluster, how is it grounded, maybe thats what I'm missing or have hooked up wrong. Its a 68 by the way.
there is a wire that attaches to the cluster housing up near the top with a small screw, run that to something metal and attatch it giving the unit a good ground. try taking a piece of wire with each end bare, touch one to the top edge of the cluster and one to a good ground and see if it works. thats how mine is and it works fine...
