4 Offline
I need some help with my rally gauge cluster, the factory indash type. I am getting absolutely no power to it, lights do not even work. The cluster itself is a used original, the dash harness is new, all fuses are new and I even just tried a new printed circuit. Still no power. I have power to the rest of the dash, wipers, radio, heater, horn, except not to the cluster. Any ideas??????????
Tom
68 Firebird 400 4speed
No, but I had no power to my rally guages only last week. Gave up for now and put a temp pwr wire in from the accessory tab (switched) on the fusebox to one of the guage taps. That backfed the rest. Not saying finding the problem is not a good idea, but it all works now.
David
68 Droptop 400 4 spd.
Have you checked voltage at the feed from the fusebox? From there, check for voltage at one of the gauges to ground.
Vikki
Restoration Gallery
http://thefirstgensite.com
I
I Offline
Make sure you have the gauge pod grounded.
Tom
'69 Firebird 400 4spd conv
4 Offline
Well I have power at the wiring harness coming into the cluster, how is it grounded, maybe thats what I'm missing or have hooked up wrong. Its a 68 by the way.
Tom
E
E Offline
there is a wire that attaches to the cluster housing up near the top with a small screw, run that to something metal and attatch it giving the unit a good ground. try taking a piece of wire with each end bare, touch one to the top edge of the cluster and one to a good ground and see if it works. thats how mine is and it works fine...
Posts298,897
1 members (Dennis in Indiana), 161 guests, and 25 robots.
JFF 1
