Probably a longshot but you can steal a little up and down adjustment on the top frame by adjusting the Allen set screw stop at the first joint back from the front, just a little. The way we checked door and trunk seals on new cars at the dealer that needed adjustments was to use a crisp dollar bill and it should be able to be pulled out with the door closed but be a firm pull. You also check it in all different spots. One other idea is that door glass factory or aftermarket?.
68 Convertible Window Adjustment csell_willys 01/23/22 03:10 AM
Re: 68 Convertible Window Adjustment Dennis in Indiana 01/23/22 04:04 AM
Re: 68 Convertible Window Adjustment Dennis in Indiana 01/23/22 04:23 AM
Re: 68 Convertible Window Adjustment Dennis in Indiana 01/23/22 04:39 AM
Re: 68 Convertible Window Adjustment csell_willys 01/23/22 10:43 PM
Re: 68 Convertible Window Adjustment csell_willys 01/23/22 10:46 PM
Re: 68 Convertible Window Adjustment Dennis in Indiana 01/24/22 01:03 AM
Re: 68 Convertible Window Adjustment Dennis in Indiana 01/24/22 01:51 AM
Re: 68 Convertible Window Adjustment Dennis in Indiana 01/24/22 02:02 AM
Re: 68 Convertible Window Adjustment csell_willys 01/24/22 03:25 PM
Re: 68 Convertible Window Adjustment Dennis in Indiana 01/25/22 02:48 AM
Re: 68 Convertible Window Adjustment csell_willys 02/16/22 03:42 PM
Re: 68 Convertible Window Adjustment csell_willys 02/18/22 04:45 PM
Re: 68 Convertible Window Adjustment barnbird 02/18/22 07:05 PM
Re: 68 Convertible Window Adjustment csell_willys 02/18/22 09:21 PM
Re: 68 Convertible Window Adjustment csell_willys 03/25/22 01:34 AM
Re: 68 Convertible Window Adjustment csell_willys 03/25/22 01:39 AM
Re: 68 Convertible Window Adjustment Jimc2002 03/25/22 05:46 PM
Re: 68 Convertible Window Adjustment csell_willys 03/25/22 06:29 PM
Re: 68 Convertible Window Adjustment csell_willys 03/28/22 07:34 PM
Re: 68 Convertible Window Adjustment barnbird 01/23/22 02:21 PM
