You can bet it was my pleasure, Greg! I really appreciate the opportunity.
Vikki, The engine had 20,000 original miles on it when it was rebuilt. It was rebuilt using all NOS parts. It has the original bore and cam specs. I'll happily provide any further specs but I time it by ear. I can't see going to the trouble of a light when you can time it by ear. If I ever loose my hearing I'll definitely get a light. I haven't run a compression test. I would only use the results for comparison between cylinders. I have yet to see a test give acurate results. I can asure you that the compression ratio would be exactly the same as a new factory engine.
