#165211 05/11/09 02:03 AM
i am unsure as to what this is... on the driver and passenger side near the feet there is something that pulls out about 3 inches on each side... what is this?
im only 15 but doing all the work on my bird, cant wait to get her on the road!
FACEFIRST #165212 05/11/09 02:12 AM
fresh air vents in a non-air conditioned car. If not rusted, when you pull the lever a flap will open behind the kick panel and divert air from the fender into the interior.
Vikki
Restoration Gallery
http://thefirstgensite.com
Yellowbird #165213 05/11/09 02:19 AM
Actually, those are the top-secret "Ram Air" pull switches. Sounds like your car was equipped with the very rare dual-pull system
FireBenz #165216 05/11/09 02:55 AM
Fire benz is right. The problem is that both have to be pulled at the exact same time by the driver while travelling at 42 mph. Otherwise, they won't work.
Bronze Bird #165221 05/11/09 10:50 AM
oh alright i was wondering about those.
FACEFIRST #165260 05/11/09 04:49 PM
I
I Offline
If you have a non A/C car you have two sources for fresh air, the kick panels and ball vents. The kick panels have a slide on the panel that operates a damper door. The pull under the dash operates the ball vent damper; it's way up under the dash, and ducted to the ball vent.
Secret Ram Air... that's original FireBenz. wink
Tom
'69 Firebird 400 4spd conv
if6was9 #165262 05/11/09 04:54 PM
D Online: Content
don't forget that when the seals are bad, they are also known as "fresh water vents"
if6was9 #165283 05/11/09 07:13 PM
Thats on 68's-n-9's.
67's had the 250 RA.
My car hates me...
Region Warrior #165292 05/11/09 09:10 PM
In other words, 250 RA was forced through the cockpit via vents in the door glass,forcing additional thrust on the gas pedal via the drivers foot.
David smile
http://FirstGenFirebird.org/show/closeup.mv?CarID=571
If i don't get this car back on the road soon i'm gonna go postal!
On a quest for FGF knowledge
1968 Pontiac Firebird Convertible
1969 Oldsmobile Cutlass "S" Convertible *Sold*
I
I Offline
David smile
A vicious circle...
Tom
