P
P Offline
At a local car show this week an unknown who to know all was determined to find flaws in my 67. He assured me that I had my headlights mixed up and the high beams should run on the outside and low beams on the inside. I looked at the wiring diagram and it said the opposite BUT another diagram showed he was correct. Who is right? Also, on a 67 vin code tag, is the tag painted the color of the car or is it bare metal? Thanks guys!
C
C Offline
Low beams should be outside. Highs inner.
Tag was bare metal on our 67 parts car
I thought the metal cans behind the bulbs match up with molded tabs on the headlights that prevent you from mixing them up?
But that's OK. I laughed to myself at my last car show at a fellow '67 FB owner who had reversed the front turn signals.
I thought it was pretty obvious how they SHOULD fit, but...
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
P
P Offline
Same for the cowl tag? Bare metal right?
I think it is DOT regulations that the low beams are on the outer and highs on the inside...I've never seen otherwise on any car??? Sounds like some leg pulling going on....
P
P Offline
This dude was pretty insistent however how could I argue with this guy? He told me he had the same car back in 1965 so he has to be legit!!
I would have asked to see HIS FGF....I've had a few of those....some are tolerable and informative, others are just plain belligerent. Those are the ones I ask to see theirs...and they usually make some excuse as to why its not at the show...or ...
Lows definitely on the outside, for one reason, as width markers in everyday (nite) driving.
David
68 Droptop 400 4 spd.
P
P Offline
I've seen two 67's in the greater cleveland area with mine being one of them but run into seven people a day that had one!
What about bare metal vin & cowl tags? My cowl is black but should it be bare? Vin?
he must have been the dad of the guy I met...he said he liked my car and that his parents had had one just like it , "but a 65".....lol
low beam on outside....to indicate where the car is when you drive with lights on, high beams go inward
P
P Offline
I figured he mocked one up in his garage in 65 and sold it to Pontiac in late 66! That has to be it!
Maybe him and John D. whipped up the mock-up in his garage back in '65.
Lol, or whatever drugs the guy was on, he still thinks it's 1965.
P
P Offline
He had a turbo diesel in his standard from Pontiac!
Seriously, are your cowl and vin tags painted or bare?
Mine are both painted black.
P
P Offline
Is your VIN tag black also?
You have a '67, your vin tag is on the door jamb, mine is on the dash, '68, but it is black along with the black interior.
I'm not sure, but i'd guess the jamb tags are the original color of the car, or just plain metal depending on when they were put on at the factory, and i'm not sure about that.
P
P Offline
Yes it is in the jamb. it is painted the same color as the interior!
'67 tag is bare metal. (not painted) Mounted on the driver's front door jamb.
'68 tag is on the firewall painted black to match the remainder of the firewall.
'67 VIN tag is on the door jamb, and is unpainted. '67 cowl tag is underhood black.
'68-'69 VIN tag is on the dash, is a black oxide tone (not paint). Cowl tag is underhood black.
Vikki
Restoration Gallery
http://thefirstgensite.com
Same here.
1980 Turbo Trans Am
Vikki
Diddo Here too!!
Juan cool
Vin tag not painted on 67's!!!
Don't you just love those guys who like to point out all the "wrong" stuff on your car?
It's shear jealousy.
Have you ever played Car Show Bingo? It's a great way of those comments into fun.
1980 Turbo Trans Am
Another det-det-deee wink
You are correct. All high beams are inner on GM's.
The vin tag(on doors) where NOT painted.
My car hates me...
I had one guy literally "gloat" over the fact my shifter was not correct (flat instead of round)...I nicely mentioned I had the round one at home waiting to go in but I knew where it might fit nicely if i had it in my hand. LOL
David
I
I Offline
How much crack did the guy have to smoke? smile
Tom
'69 Firebird 400 4spd conv
Posts298,896
0 members (), 114 guests, and 25 robots.
