Hi, I am going to change my cam since I have a lot of the motor apart and need advice. I have a '75 400 with stock internals, stock 6x-4 heads, 600cfm carb, Ed Performer intake, and headers. Choice between Summit's 2801 or 2802. Thanks, Jason
Forgot an important consideration. Unless you are planning on removing the heads, stick with the stock lifter. Reason being, the pushrod holes need to be elongated for clearance on Pontiac engines. When it's time to get the heads refreshened, then do elongate the pushrod and switch to a higher ratio.
