Well I ripped this apart 6 months ago and i will be ^$#%^& if I can figure out how the lever that connects to the e brake cable fits in this drum brake mess. Any pics would be great
My axle is still out, but the brakes are assembled so you can't see a whole lot on how it's assembled unless the axle shaft is out and the shoes removed.
The top of the lever is inserted into the top triangle-shaped hole on the rear shoe.
It's dead center of the pic I attached. I know it doesn't help much.
Duffs, if you need any parts let me know. I have some from my Bird as well as the entire drum set up from the LeMans just laying around. If you are missing something let me know and you can have them if I have what you need...
