S Offline
GM p/n 9785884 or 9789817 clutch fork return spring extension for the 4spd V8 does not appear to be available on the aftermarket. I have seen the recommendation that I buy a extension for a 6 cy (9785902) and cut it down.
Has anyone seent the correct extension available and if not, do you know what the length of the V8 extension is supposed to be?
Thanks
It's available at Classic industries and other after market places.
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
Never heard of an extension for the clutch fork. What is it and why do you need it?
We used the 6 cyl and cut down.
Bob, without it you cannot stretch the original clutch pedal return spring far enough to reach from the fork to the frame bracket.
Vikki
Restoration Gallery
http://thefirstgensite.com
S Offline
Vikki,
Thanks. Any idea how long the V8 extension is supposed to be?
I don't have specific dimensions but I'll get a measure of ours.
Vikki
Restoration Gallery
Ah. I was thinking of something else. Pretty sure I just expanded the last few coils of mine so it reaches. Not the way it's supposed to be I suppose, but it works.
I have this same problem too. Anyone know the correct length for the extension rod to be cut for a V8 car or have a pic of it already cut down? I have the 6 cyl one, I just need to cut it down now but I can't find a single picture or length dimension of what I need. ??????
I can measure also.
I purchased the extension rod for a V8 through Classic Industries, and it was way too long....ended up cutting it almost in half then re-bending the end of it to form a new eyelet for the spring to fit into. I just "trial and error'd" it till the tension was close.
1967 Firebird 400/4spd all numbers matching
1971 Camaro Pro ET Drag Car
1970 Camaro real Z-28 (needs everything)
1963 Impala 409 dual quad 4 spd
2003 Victory Vegas
2009 Pontiac G8 GT
(My wife says I have a problem.....)
If you dont hook this up, will you not have any clutch at all?
Does anyone have a pic or diagram of it, how its hooked up?
The return spring pulls the throw out bearing away from the clutch forks when the clutch pedal is released. Without it the bearing would make contact with the clutch forks and probably burn out quickly.
Hank K.
Green Bay Wis.
Posts298,896
1 members (Jimc2002), 129 guests, and 20 robots.
JFF 1
