Last night for the first time, I turned off the ign ition on my bird, and noticed the alt, or gen light came on, I turned key on and light went out, turned key off and light came on again, Ive tried to find cause, but am having no luck, HELP, If you can help, I would appreciate it , thanks
Give your voltage regulator a good 'rap' with the handle of a screwdriver. The regulator is bolted to the upper part of the firewall. It is about 2"x2"x2" or so, and usually is gloss black. I've had this intermittent problem on my '67 since I replaced it. It acts up on mine every couple of months or so. I haven't replaced it because this high tech fix seems to work fine.
awesome, thank you very much, been beating myself up over it, didnt think of that, works great, wondering if i lay a hammer next to it, if it will behave, LOL, thanks again
For what it's worth, the problem seems to diminish over time. But it has taught me to really pay attention to the idiot light when I remove the key from the ignition. My mechanic buddy said this was a common issue with replacement regulators dating way back when.
I
I Offline
Do you have a internal or external regulator? External is on the firewall, internal is in the alternator. If you have the internal, the diode has gone bad.
Tom
'69 Firebird 400 4spd conv
external volt reg. tapped it, and light went out, who knew, well, I guess the guy that said hit it with a screw driver, thanks
No problem. That'l be $49.99. I take cash! smile
Topics35,545
Posts298,891
1 members (Jimc2002), 96 guests, and 26 robots.
JFF 1
