Posts: 5,139 |
Sports fans, It appears I am screwed again for some reason....removing the REAR drivers side tire/rim today and four lug nuts loosened up easily....the fifth did not, but after a little force the fifth nut started to spin....but now it continues to spin and not come off. That means the threaded stud within is spinning endlessly.....what to do? How do we get at that stud and anchor it?
Posts: 5,139 |
Of course, it could also be a stripped nut that is spinning, I suppose...I don't think so as it would eventually shear and easily pop off the stud.
Posts: 1,923 |
Do you have any play at all? If so, you can get on the nut with a long breaker bar & socket and work it side to side until it breaks. Then just replace the broken stud.
Posts: 48 |
nashville68bird.....If the stud is turning with the nut, it's no good anyway. Cut the stud off, and replace it and the nut. You may need a stud with an oversize sholder if the hole in the hub is enlarged. Put the new stud in from the back. Put a couple big washers on the stud in front and pull it into place with the lugnut on backwards......John
Posts: 3,049 Likes: 10
Posts: 3,049 Likes: 10 |
It's tricky with the wheel still on. You don't want to screw up the finish. But try taking a cutoff wheel and making an X cut in the top of the lugnut until you get to the stud, then you have to use a cold chisel and start peeling the lugnut back. You may not have to get it all the way as it will start to loosen up while you do this.
Good luck!
Posts: 1,363 |
Concur with the cutoff wheel option. Had a similar problem many years ago and ended up cutting one slot as close to the wheel as I could get. I was limited by the position of the cutoff wheel to make only one good cut. Then busted the nut out with a chisel.
Larry 1967 Sprint Convertible
Posts: 1,363 |
The other option if you truly believe you have broken the lug nut loose is to put a standard wrench on the lug nut and clamp a large vice grip on the stud. Then turn the stud with the vice grip. Once you get the lug nut most to the way off, put the vice grip on the back side of the stud. You'll need to be careful to prevent scraping the wheel though.
Posts: 780 |
Dremel tool with a heavy duty cut off wheel...
Posts: 20,054 |
if you can use a cut off or dremel , cut the nut and stud in two ,right down the center , split them, take wheel off ,replace stud and nut
Posts: 1,534 |
Nash, I hear this doesn't happen if you use Buick rims. LOL!
Posts: 20,054 |
Nash, I hear this doesn't happen if you use Buick rims. LOL! no, its only if you use Buick lug nuts!
Posts: 1,394 Likes: 2
Posts: 1,394 Likes: 2 |
I had the same problem a few years back with some new lugnuts gauling the threads. But I was lucky enough to be working with a c clip rear end. I just pulled the diff pin and slid the axle out. From there I ground the head off.
Posts: 10,338 Likes: 3
Posts: 10,338 Likes: 3 |
no, its only if you use Buick lug nuts! Hey! Who ya callin' a lug nut?? Be nice!
Posts: 20,054 |
no, its only if you use Buick lug nuts! Hey! Who ya callin' a lug nut?? Be nice! sorry ,didnt know you were so sensitive!
Posts: 9,027 |
Isn't it Buicks one sells at the toilet after a hard nite of drinking!
I would perhaps replace all the studs to be on the safe side. I had the same sort of issue with my F150 and the other ones were stressed as well from the 2 broken studs. I knew that because I replaced two broken ones , tightened up the remaining ones and two more snapped off! Never had that happen before, and it has 6 studs!
Posts: 5,139 |
No easy fix C-clip on my bird, had to cut out and break down the one Rally nut that was spinning, and did it tonight with relative ease.
Man, those aftermarket Rally lug nuts have our lives in their hands, but they are pretty soft aluminum, trust me.
Had a complete set of rear studs on the shelf, so should be back out on the road "scaring women, horses and children" by tomorrow night. Thanks to all as always for the advice and posts.
Posts: 5,139 |
Using a Camaro lug nut to get by for now. If Anyone has a Firebird Ralley Wheel nut (black insert) on the shelf and can drop it in an envelope for me it would be appreciated, and I'll mail you back a few bucks, or let me know what small part you need in return:
John Alvey 882 Countrywood Drive Adams, TN 37010
Posts: 9,027 |
I need one too, Tom (Banshee) was going to send me one. I have a stock one on now. Tom? are ya reading this!  I'll send him a note on FB right now....
Posts: 9,027 |
I see Ames sells singles for $2.50 ea. If I don't hear back from Tom I'll order a few tomorrow and send you one.
Posts: 9,027 |
Ordering 4 today from Ames. Let me know if you need one.
Ordered. PM me with your address and I'll send you one as soon as they arrive.
Posts: 5,139 |
Dave from Canada sent me the perfect replacement lug nut for our 1968 Birds. Thank you very much Dave! Hmmmm...now what to send him back as a thanks? Hillary Blow-Up Doll?
Posts: 9,027 |
No NO! , not a Hillary Blow up Doll!
Posts: 5,108 |
My eyes! My eyes! Gon'a have to work late, drink extra beers, and couple 2-3 shots of JD to sleep w/o nitemares.
Posts: 20,054 |
well, I think she looks better there than in real life! LOL
Posts: 9,027 |
Press the button Hillary!
Posts: 9,027 |
I'm somewhat concerned about these aftermarket rally nuts. I repaired one stud a few weeks back that had cross threaded coming OFF and had to pull a wheel yesterday and another one cross threaded coming off and I know they were on straight and torqued to 100 ft pounds. I think the metal is too soft.
I also found nuts loosening up and now check em regularly...
are there more than one manufacturer?
I cant recall where I got this set from...think it was classic
Posts: 6,758 |
I cant recall where I got this set from...think it was classic If the metal in the nut was weak then why does the stud fail and not the nut?
Posts: 9,027 |
Seems the threads on the nut deform when its torqued on, then cross thread on the way out. I use a standard lug nut to pull the studs thru and have really put torque on them in some instances and they are just fine.
I see a lot of metal on the threads on the nuts when they come off and the threads look soft/worn. The stud threads seem crisp and untouched.
Posts: 20,054 |
sounds like it had the wrong thread?
Posts: 9,027 |
Nope, thread is correct. Spins on nicely and most spin off nicely, except the odd one once n awhile. Never had that problem before on any cars.
I cant recall where I got this set from...think it was classic I bought my set from Terry back in '07. I haven't had any issues like that. I've had my wheels off-on a couple of times since then. No idea on MFR. though.
Posts: 9,027 |
I got 3 from Ames to replace the bad ones (one I sent to Nash) so will see how it goes with them. May replace them all once I have confirmed quality. Pretty sure I got the others off Ebay, so no idea where they originated.
Off to Penticton next week for the Beach Cruise Show, so will be checking them regularly.....its a winding road up!
167
