L
L Offline
Trying to find a pair of horns for a 1968 firebird and need the part numbers for same.
Have to check my 73 catalog at home to see if numbers changed, but our 83 cat here at work lists;
LH #1892164/high note
RH #1892163/low note
My car hates me...
L
L Offline
Thank for the info, I'll run with those numbers
W Offline
What came on a Standard '68 Firebird? The Sales Manual notes for the custom option:
Exterior Appointments:
° Bright metal wheel opening moldings at front and rear.
° Handsome, chrome-plated deluxe wheel discs.
° Dual horns.
Dual horns also appears to be an separate option, 414. So, assuming that 414 and custom interior were not selected, what would I have gotten?
Single horn, standard interior, no wheelwell moldings, standard hubcaps
http://thefirstgensite.com/library/partscounter/illustrated/misc/caps1.jpg
Vikki
Restoration Gallery
W Offline
Thanks for the information. Saved the cost of one horn!
It would have been the low. The high, alone, sounds like a moped horn.
I did come across something odd in the parts index. It shows the high on the left core support, the low in the middle. I just assembled my horns a couple of weeks ago, and the high definitely fit in the middle. Anyone have a car without the filler plates installed to verify?
http://thefirstgensite.com/library/partscounter/illustrated/elect/elect2.html
Vikki
Restoration Gallery
W Offline
My horn was non functioning when I got it. It was located on the center portion of the core support as the drawing you linked noted. I had several people tell me I was supposed to have two which is why I asked.
There will be a second female plug on the outside of the left core support if your car came with two horns.
Vikki
Restoration Gallery
L
L Offline
My car has two plugs also.
1 members (Jimc2002), 114 guests, and 19 robots.
