Posts: 6 |
Trying to find a pair of horns for a 1968 firebird and need the part numbers for same.
Posts: 5,108 |
Have to check my 73 catalog at home to see if numbers changed, but our 83 cat here at work lists;
LH #1892164/high note RH #1892163/low note
Posts: 6 |
Thank for the info, I'll run with those numbers
Posts: 2,113 Likes: 1
Posts: 2,113 Likes: 1 |
What came on a Standard '68 Firebird? The Sales Manual notes for the custom option:
Exterior Appointments: ° Bright metal wheel opening moldings at front and rear. ° Handsome, chrome-plated deluxe wheel discs. ° Dual horns.
Dual horns also appears to be an separate option, 414. So, assuming that 414 and custom interior were not selected, what would I have gotten?
Posts: 11,905 |
Thanks for the information. Saved the cost of one horn!
Posts: 11,905 |
It would have been the low. The high, alone, sounds like a moped horn. I did come across something odd in the parts index. It shows the high on the left core support, the low in the middle. I just assembled my horns a couple of weeks ago, and the high definitely fit in the middle. Anyone have a car without the filler plates installed to verify? http://thefirstgensite.com/library/partscounter/illustrated/elect/elect2.html
My horn was non functioning when I got it. It was located on the center portion of the core support as the drawing you linked noted. I had several people tell me I was supposed to have two which is why I asked.
Posts: 11,905 |
There will be a second female plug on the outside of the left core support if your car came with two horns.
Posts: 6 |
My car has two plugs also. There will be a second female plug on the outside of the left core support if your car came with two horns.
1 members (Jimc2002),
101
