M Offline
Car is a 69 FB 400 4 speed, no air, ps car.
They just have to be parts that will clean up well in the cabinet and maybe with some filler. Bolt heads clean please.
Here are some needs:
-starter brace
-f-4 throttle bracket
-coil bracket and spark plug wire holder for above
-breather tube valve cover to air cleaner
-intake manifold bolts
-exhaust manifold heat shield
-choke stove
-windshield washer squirters for under the cowl
-bell housing to block bolts
-flex fan #9791346 , spacer and bolts
-#9796351 water pump (Late Dec,Jan dates)
-just the handle and clip for a 69 hood latch assembly-if all
then all.
-plug for intake manifold for manual trans
-proper bolts for thermostat housing
-water pump bolts and t
-oil pan that can be worked
-manual trans lock out mechanism
-Muncie 4 sp shift linkages
-Shifter mounting plate
Thanks,
C
I have an entire '69 latch assembly. Already blasted and primed, ready for paint. Possibly would seperate depending on which clip you are referring to. I also have an F-4 bracket.
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
Hi
I have these items
starter brace
f-4 bracket
coil bracket and plug wire holder
b/tube
intake bolts
choke stove
heat sheild....maybe
bellhousing bolts
flex fan.... stainless...Ille have to do a number ck.
................. got 2 hangin in rafters
water pump...only earlies I think
intake plug.....probably
proper bolts for thermo housing yes correct ones
waterpump bolts and studs...correct slotted ones
1 REAL nice pan
shifter plate
Scott
[email protected]
with a contact number
punctual pics and shipping for serious buyer
I've got a starter brace that is already bead blasted. I also have most of the proper bolts but it sounds like Scott has most of those for you already.
Bill Edmunds
[email protected]
A
A Offline
I have a 69 Water Pump 11 bolt stamping 122.
I may have the lock-out piece you are looking for.(page 2 of pictures)
Pictures of stuff at http://s170.photobucket.com/albums/u276/ammscl/Parts/
Let me know Ray.
M Offline
That was a good first fishing trip for parts
We still are in need of
-starter brace
-coil bracket and spark plug wire holder for F-4 throttle bracket
-choke stove
-flex fan #9791346 spacer and bolts
-manual trans lock out mechanism rod to trans from frame mount
I posted that I have a nice starter brace and alot of the correct nuts and bolts. I have not heard from you yet but if you are interested you can email me directly at [email protected].
Thanks,
Bill Edmunds
[email protected]
M Offline
PM sent
Hey Casey, I received your pm and answered you back.
Thanks,
Bill Edmunds
Posts298,894
JFF 1
