Posts: 150 |
Car is a 69 FB 400 4 speed, no air, ps car.
They just have to be parts that will clean up well in the cabinet and maybe with some filler. Bolt heads clean please.
Here are some needs:
-starter brace -f-4 throttle bracket -coil bracket and spark plug wire holder for above -breather tube valve cover to air cleaner -intake manifold bolts -exhaust manifold heat shield -choke stove -windshield washer squirters for under the cowl -bell housing to block bolts -flex fan #9791346 , spacer and bolts -#9796351 water pump (Late Dec,Jan dates) -just the handle and clip for a 69 hood latch assembly-if all then all. -plug for intake manifold for manual trans -proper bolts for thermostat housing -water pump bolts and t -oil pan that can be worked -manual trans lock out mechanism -Muncie 4 sp shift linkages -Shifter mounting plate
Thanks,
C
Posts: 10,337 Likes: 3
Posts: 10,337 Likes: 3 |
I have an entire '69 latch assembly. Already blasted and primed, ready for paint. Possibly would seperate depending on which clip you are referring to. I also have an F-4 bracket.
Posts: 6,758 |
Posts: 309 |
Hi
I have these items
starter brace f-4 bracket coil bracket and plug wire holder b/tube intake bolts choke stove heat sheild....maybe bellhousing bolts flex fan.... stainless...Ille have to do a number ck. ................. got 2 hangin in rafters water pump...only earlies I think intake plug.....probably proper bolts for thermo housing yes correct ones waterpump bolts and studs...correct slotted ones 1 REAL nice pan shifter plate
Scott
scott68gto@comcast.net with a contact number punctual pics and shipping for serious buyer
Posts: 1,013 |
I've got a starter brace that is already bead blasted. I also have most of the proper bolts but it sounds like Scott has most of those for you already.
Bill Edmunds EarlyBrds@aol.com
Posts: 49 |
I have a 69 Water Pump 11 bolt stamping 122. I may have the lock-out piece you are looking for.(page 2 of pictures) Pictures of stuff at http://s170.photobucket.com/albums/u276/ammscl/Parts/Let me know Ray.
Posts: 150 |
That was a good first fishing trip for parts
We still are in need of
-starter brace -coil bracket and spark plug wire holder for F-4 throttle bracket -exhaust manifold heat shield -choke stove -windshield washer squirters for under the cowl -flex fan #9791346 spacer and bolts -#9796351 water pump (Late Dec,Jan dates) -manual trans lock out mechanism rod to trans from frame mount -Muncie 4 sp shift linkages -Shifter mounting plate
Posts: 1,013 |
I posted that I have a nice starter brace and alot of the correct nuts and bolts. I have not heard from you yet but if you are interested you can email me directly at EarlyBrds@aol.com.
Thanks, Bill Edmunds EarlyBrds@aol.com
Posts: 150 |
Posts: 1,013 |
Hey Casey, I received your pm and answered you back.
