3 Offline
Pulleys don't line up.Why ?
Unfortunately my company blocks pictures so I can't see what you posted but I will look tonight when I get home. Hopefully someone can figure out before then. Good luck.
Doug, I went through my pictures file and found this shot of a '68 RA with manual steering.
'68 400HO Conv.
And a shot from another angle:
'68 400HO Conv.
Can you email me the pics? Can't see close enough.
Have a look at the attached illustrations...
Attached PDF document
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
3 Offline
I'll post new pics in a little while.
Looks like wrong alt bracket for the single fan pulley.
Likely solve with different alt brack or a double fan pulley
3 Offline
The bracket came from inline tube.
I mounted it with a bolt & stud now I'm thinking I need 2 studs with nuts for spacers.
I'm hoping that;ll bring it out to where I need it.
Spacers is the way I had to go. With an aftermarket steering pump and mach pully. Go thing we have a hardware store close by with chrome spacers of different sizes. GL
3 Offline
I got it yesterday.
What I had to do is make a longer stud 7/16" longer for the top hole out of some 3/8" unthreaded rod that I have.
Lines up good now.
