I found the vin on the block finally
24863
01/26/05
09:40 PM
Aug 2004
Alton, IL
BigMike85
BigMike85
Aug 2004
Alton, IL
i finally found the vin on the block! now i need to try and decode it. It is:
22P446266
I also found the code for my rear end, it is an XF 3.23 open diff.
1988 RX-7 GTU Turbo
1968 Firebird 6.6L (6cyl orig)
Re: I found the vin on the block finally
24864
01/26/05
09:55 PM
Mar 2004
Michigan
Mar 2004
Michigan
1972 engine from Pontiac assembly plant, I believe that plant was building Bonnevilles and Catalinas in 1972.
Vikki
Restoration Gallery
http://thefirstgensite.com
24865
01/26/05
10:36 PM
Aug 2004
Alton, IL
BigMike85
BigMike85
Aug 2004
Alton, IL
how do i decode it for myself, not questioning you, i just want to know for the future
thanks
1988 RX-7 GTU Turbo
24866
01/26/05
10:38 PM
Aug 2004
Alton, IL
BigMike85
BigMike85
Aug 2004
Alton, IL
i forgot to add that it is a YX block
1988 RX-7 GTU Turbo
24867
01/26/05
11:06 PM
Mar 2004
Michigan
Mar 2004
Michigan
various sources on the web. Do a google search for Pontiac engine VIN and Pontiac block codes.
Vikki
Restoration Gallery
1stgenbirdman
Website
Website
0 members (), 431 guests, and 37 robots.
Highlander
