Posts: 24 |
Needed a set of JC stamped wheels
Posts: 1,363 |
I have 2 MI8 (1968) JCs that require restoration (basically painting). They are true and the lug holes are good.
Larry 1967 Sprint Convertible
Posts: 24 |
Should have put size on there 14x7. Not familiar with the M18.
Posts: 1,363 |
If its a 14X7 you are looking for, its not a JC. JCs were all 14X6.
JCs were made in 1967 and 1968. The 1967s were date coded MI7 and the 1968s were date coded MI8. Hence mine are from 1968.
Posts: 24 |
Ah I see said the blind man--I got the drum brakes on mine.
Posts: 1,363 |
BTW its kind of stupid that I mentioned the date codes anyway. The only way you can see them is with the tire off (inside the rim). Now you really have to be a purest to insist the inside date codes are correct.
Posts: 24 |
okay--so you have two JC's which are 14x6 and will work on drum brakes on the 68 firebird---the 5 spoke wheels right. Did you have rings & caps as well??
Posts: 1,363 |
Drum brakes are never a problem, its the disc that you need to be careful with. I don't have any caps or rings. You can still get OEM and the repos are pretty good (at least for the caps). Trim rings are another story. Someone else needs to chime in because I am still looking for a set of trim rings and I am still confused as to what looks correct.
Posts: 24 |
how for the rims you have? I am in kansas.
Posts: 24 |
Posts: 1,363 |
$25/ea plus actual shipping costs. I'll try to get some pictures posted.
Posts: 1,363 |
560
