hello, when i start the engine it makes a moderate screeching sound always. its not the missing-gear-tooth on the flywheel sound but still obnoxious. i'm thinking the starter is not properly shimmed. basically its the same as it was 25 years ago (engine sat for that long). how do you know how many shims are supposed to be in ? thanks
M Offline
normally you need to have the trans off to use a wire type feeler gauge to measure the clearance. if you go about halfway down this page on my site you can see me doing the clearance measurement.
i am sure there may be other ways that a seasoned mechanic may use without removing the tranny but this is the way i know.
http://www3.telus.net/68bird/engine_install.htm
Mh68bird]
I just used a screwdriver to pry the pinion gear out of the starter to engage the flywheel and used a piece of welding wire 0.035" to check my gap. All while the transmission is in.
[Linked Image from imageshack.us] I know that washing and waxing my car with the present condtion of my paint is like polishing a turd.....but it's my turd and I want it polished!
a paper clip will work if you don't have welding wire to check the gap.
Harry 69 Firebird
_________________________________________________
1969 firebird 350/auto
2012 mustang v6 (wifes car)
2012 jeep compass (winter vehicle)
2008 dodge ram 4x4 Hemi
x 2 on the paper clip. Worked perfectly.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
I read that there should be a 1/8" gap between the shaft and the ring gear. I use a piece of 1/8" weld wire bent atthe end.
thanks guys !!! great info, i had no idea about this.. i will report back what i find as soon as i get a chance to go out in the garage (getting cold up here already) !!!
Posts298,896
0 members (), 114 guests, and 25 robots.
